Specifies the anycast gateway MAC address that is used by VLANs that enable IP anycast.
| ip | Layer 3 Internet Protocol. |
| anycast | Configures IP anycast. |
| mac | Configures the IP anycast MAC address for VLANs with IP anycast enabled. |
| none | Unconfigures the previously configured MAC address. |
| mac | Specifies the MAC address. |
N/A.
Use this command to specify the same IP address and MAC address on all edge technology devices. This allows seamless IP mobility in the network for edge devices. Using the none option unconfigures the previously set MAC address.
The following example specifies the MAC address as 00:00:AB:BA:BA:BA:
# configure ip anycast mac 00:00:AB:BA:BA:BA
This command was first available in ExtremeXOS 30.6.
